out of control idle with holley
Old Apr 29, 2005 | 06:35 PM
barspin89's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
I switched from a Q-jet to a holley 600 and can not get it to run right. The engine knocks at idle in gear and every few days the idle will jump to 2000 rpm's when I turn it on. I'm wondering if this has anything to do with jet size or if it's another matter altogether. Right now I'm running size 60 jets. Any info would be appreciated
Also if anyone knows how to re-wire a 700-R4 to work without the computer, please send any info my way.
barspin89
85 TA
305 LG4
Edelbrock Performer intake
Old Apr 29, 2005 | 07:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: out of control idle with holley
Is the choke closed when it does this?
A search in the transmission forum should turn up lots of info.
Old Apr 30, 2005 | 10:57 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
How did you route your vaccum hoses? Did you swap out your distributor when you changed carbs? Electric choke or manual? Sounds like when the engine goes up to 2000 it's just the choke doing it's job.
Do you mean torque convertor lockup? Check out this thread of mine...
https://www.thirdgen.org/techbb2/sho...61#post2315461
Old May 1, 2005 | 12:49 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
You need to adjust the fast idle screw down some.
With the car off go WOT and look on the pass side of the carb. There will be a screw at the bottom of the linkages. Unscrew it some and then start the car again.
Do you still have the papers that came with the holley? Its all in there.
BTW I have no computer. And never wired my 700r4 up. I just haven't use the TC lock-up.
Old May 7, 2005 | 07:28 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
When i put my Holley on i had the same problem,I found that the secondairy set screw was holding the secondairies open slightly.Didn't matter how much i set the idle screw down it still idled high.The screw is located at the back of the carb on the passenger side,you have to get at it from the bottom so you'll have to probably take the carb off to adjust it.
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
