Demon Carb Problems
Old May 5, 2005 | 12:39 AM
TEQUILA911's Avatar
Car: 1988 Z28
Engine: 355ci big cam,wrp heads,demon carb, blue printed and dynoed at 447 hp and 479 torque
Transmission: 700r4 by monster motor sports
Demon Carb Problems
Went to demons web site after I bought the speed demon 750 for my 355 because cam has more than 242 degrees duration to it. I can't seem to get the motor to idle correctly. I did the warm up and fuel bowls, and adjusted the air mixture. What else can I do.
Old May 5, 2005 | 12:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you running ported or full-time vacuum advance?
Old May 5, 2005 | 12:55 AM
TEQUILA911's Avatar
Car: 1988 Z28
HEI with VAC adv
hei distrib w vac adv and hyfireVI ignition
Old May 5, 2005 | 12:58 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, but where is your vacuum advance connected?
Old May 5, 2005 | 01:00 AM
TEQUILA911's Avatar
Car: 1988 Z28
vac
vac is attatched to the bottom port of carb
Old May 5, 2005 | 05:49 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
but which bottom port on the carb? the front is timed vacuum and the rear is ported (manifold) vacuum
Old May 6, 2005 | 08:17 AM
TEQUILA911's Avatar
Car: 1988 Z28
carb
Timed vaccume port sorry was sure what you were trying to get at.
Old May 7, 2005 | 01:43 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
You probably need to swap power valves, what power valve is in it now and how much vacuum are you pulling at idle?
Old May 9, 2005 | 10:07 PM
TEQUILA911's Avatar
Car: 1988 Z28
vaccum
vaccum on the gauge is at idle 16 has big cam and doesn't pull much vaccum
Old May 9, 2005 | 10:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not that big if you've got 16" at idle.
Old May 9, 2005 | 11:46 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Sounds like you have plenty of Vac at 16 in.
Try this ******* trick.
At idle pull off a vacume hose to create a leak induce morte air to the misture. If the engine runs better then the idle mixture is too rich.
At idle put your hand over the card like a choke reduce air into the mixture. If the engine idles better then it is too lean.
You can adjust the mistures screws using this method in a pinch.
You can also set you mistue by the gage turn one screw until vac is maxmized then turn the other until max vacume.
Is the timing set too low? / Where are the throttle blades in relation to the idle transfer slots?
Old May 10, 2005 | 12:49 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I had a hell of a time getting my Demon to idle rich. Turns out I had to drill out the idle air bleeds, still not perfect but it made a world of difference. The transfer slots are squared, all 4 mixture screws are just slightly more than 1 turn out and the air bleeds were drilled out to .073 16* initial timing no vacuum advance, idle at 750RPM in gear.
Old May 10, 2005 | 04:52 PM
TEQUILA911's Avatar
Car: 1988 Z28
Carb
OMG
Called comp cams and timed engine to there specs 10* BTDC and was able to adjust carb and timing on engine. The motor makes great power in Drive and going through gears and idles at 750 rpm with great throttle response and lopy idle and makes 15 inches of vaccum. All I can SAY is WOW!!!!!!!
Old May 10, 2005 | 05:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Another success story of fixing the carb by fixing the ignition...
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
New2Chevy
Oct 4, 2015 11:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
