vacuum lines
Old May 29, 2005 | 12:24 PM
barspin89's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
vacuum lines
I recently installed a new intake on my LG4 with a holley 600 and I can't get it to idle properly. It idles very shaky with the rpm's bouncing around and there is a lot of knocking coming from the engine compartment. I'm wondering if I have my vacuum lines hooked up right. This is how I have it hooked up: I have on line from the distributor vacuum canister to the carb, I have a line from the carb to the brake booster and pcv valve, and I have one line that runs into the firewall by the wiper motor from the carb (I have no idea what this line does). I do not have any lines into my manifold and I'm wondering if I should. Any help would be appreciated.
Old May 29, 2005 | 01:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In the interests of safety, the brake booster should have its own line. Use seperate ports for the brakes and the PCV.
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
