Edelbrock fuel pump for SBC?
Old May 30, 2005 | 04:53 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I just purchased an edelbrock 1721 mechanical fuel pump for my 383 stroker and I took the block off plate off and the pump does not cover the hole!!?? The part that actually need to meet the block top bolt up needs to be longer so do I have the right model number or what. I checked and it says that the 1721 is for the SBC so any ideas?
Old May 30, 2005 | 06:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're missing the fuel pump mounting plate, which is what the block-off plate replaces. It looks the same, with a large oval-shaped hole in the middle.
Just as a warning, you'll probably need the adapter for that pump to relocate the fuel inlet and outlet ports to the bottom.
Old Jun 7, 2005 | 06:56 PM
Car: 85 Z28
Engine: 383 Stroker
Where can I get one? Jegs, Edelbrock prolly?
Old Jun 7, 2005 | 07:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
junkyard
Old Jun 7, 2005 | 07:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A junkyard, or if you really don't want to find a used one, Mr. Gasket, Trans-Dapt and others make cheesy chrome plated ones.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
evilstuie
Jan 9, 2020 08:29 PM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
