idle lowers when on an incline
Old Jun 3, 2005 | 08:48 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I was stopped at a steep hill and notice that the idle went down from 650 to below 500.Could it be the float level(front or back?)
Its an 1850 600cfm Holley Vac secondary...
Old Jun 4, 2005 | 08:53 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Sounds like you might be right. I think that it could be the rear float, because of the incline the fuel is shifted toward the rear of the bowl. Similiar to if you launch hard when running at the track. Not positive if that is the cause but it makes sense.
Old Jun 6, 2005 | 07:12 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
Hey Daz, did you convert your car to carb?
Old Jun 7, 2005 | 07:24 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
yeh..My IROC and the 91 Roadmaster
Old Jun 7, 2005 | 09:34 AM
Car: 87 IROC
How hard was it to convert your IROC? I've been thinking about pitching the TPI on my car in favour of a carb setup. I've read up on the swap, it doesn't look too hard. I guess the fuel pump would be the most amount of work. Where you able to use the stock linkage or did have to fab something up?
Old Jun 7, 2005 | 09:55 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
The IROC has a BBC and the linkage was perfect.
I made a mistake and hack the wiring so my heater controls doesnt work but everything is very easy
Prodigious
Oct 4, 2015 11:20 PM
gta90
Sep 15, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
