Help: What carb should i use??
Old Jun 6, 2005 | 01:35 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Hey, I'm not the best at picking out carbs for engines, so I was looking for some help. I have a 406 with 10.43:1 compression with Brodix aluminum heads, roller cam .540/.556 lift and 234/240 duration at 50. I'm going to be using 100-150 shot of nitrous pumping race gas from a separate container. Power band ends at 6800 with a single plane weiand stealth manifold. This is a mildly used car. Driven maybe 4 times a week, mostly for race but would like street use as well. I was wondering what the best size carb would be for this application, and would a double pumper be more efficient or stick to vacuum?
I have a holley 750 vacuum secondary which I was using on my blower. Would I be able to reuse this? Thanks.
Old Jun 6, 2005 | 01:49 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
You could reuse that or I would definitely look into a DP, either 750 dp ro 850.
Old Jun 6, 2005 | 11:38 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I would say 750 double pumper
Old Jun 7, 2005 | 04:57 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
def look into getting a dp, the vac secondaries are a pai imo...
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
