305 tbi to a 350 carb
Subscribe
Jun 15, 2005 | 11:31 AM
hey i have a 305 with a tbi and am lookin to get a 350 witha Edelbrock 650 vacuum secondaries carb on it and i need to know if i will need a new fuel pump or if the stock one will be fine also is there anything else i will need to get to make the swich from the 305 to the 350
thanx in advance
Reply 0
Jun 15, 2005 | 11:48 AM
check out this thread. Tpi to carb swap.
If you use the intank pump, and a adjustable fuel pressure regulator, you should be ok. The stock TBI pump puts out about 15 psi and a carb only requires 5 to 7 psi. The regulator has to be a return style.
I swapped from a 305 TBI to a 350 TPI motor. No I have converted over to carb. Good luck and welcome to the board.
Reply 0
Jun 15, 2005 | 11:51 AM
Here is the adjustable fuel pressure regulator (afpr) I used.Mallory AFPR
Part #MAA-4309
Reply 0
Jun 28, 2005 | 11:38 AM
Quote:
Part #MAA-4309
Yeah I swapped from a 305 TBI to 350 carb and used that unit as well. Works good.
Reply 0
Subscribe
