why do i smell like exhaust
Old Jun 23, 2005 | 07:19 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
after a 30 minute drive when i get out of my car i still smell like exhaust all over me? behind the car it smells really rich to the point my eyes hurt, i look at the a/f gauge and it's reading normal, i have a cc q-jet, gutted cat and edelbrock cat back
Old Jun 23, 2005 | 07:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do you have any exhaust leaks?
Old Jun 23, 2005 | 07:54 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
no i dont
Old Jun 23, 2005 | 08:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well if it smells that rich, it has to be rich, regardless of what your A/F gauge says.
Old Jun 24, 2005 | 03:42 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
it's not super rich but you can go behind it and notice it, what causes that at idle like that? i can understand wot, i get no ses codes or anything
Old Jun 24, 2005 | 05:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Stuck rods, stuck choke, leaking well plugs, floats too high/stuck/leaking, bad O2 sensor...
Old Jun 27, 2005 | 06:32 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
I can tell you that mine started running rich like that, only sometimes though and now its pretty much all the time so I figure its most likley my O2 sensor. My carb is brand new so I doubt thats it. I'm gonna buy a new one and see.
Old Jun 28, 2005 | 02:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Do you still have a cat(s)? My car has no cats anymore, and smells a little gassy from behind, but mines in basically perfect tune... runs great, plugs look right, decent mileage, etc, but theres some gassy smell there.
Just the lack of cats will make your car smell like that because theres always unburned fuel that gets to the exhaust system. If theres no cats to burn it off, you will get that smell.
Some gassy smell is normal w/o cats, but if its a really intense 'experience' though... like burning your eyes when you stand near the car, then I would at least check the condition of the plugs to see how its running, and check the timing as well.
Old Jun 28, 2005 | 08:35 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Yep, no cats or any of the smog stuff for that matter and your right, there is always a little stinch when you have no cats. Car runs pretty strong even with the new 305. I've been pretty busy and it's been raining like hell down here in Florida so I have not had a chance to pull the plugs and check out whats up. In fact, I have not driven it since it started to be on the safe side. I will post my results this weekend.
I have the timing at 14* per Edelbrocks recomendations, I just havent had a chance to play with that number yet because I have been planing to get a full MSD setup.
BTW, it's been throwing an SES light at me too, I havent polled the ECM for codes yet but I bet its O2.
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
