Carb to Intake Gasket?
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I have a edelbrock divided square bore heat insluated gasket on a manifold that accepts both square and spreadbore carbs. My carb is a Holley 4777. Is this ok? Or should I also use the metal plate that edelbrock sells for this setup?
I'm curious also to see what all you carb guys are running for gaskets inbetween carb and intake. I need to run the thicker gasket for the power brake booster set up behind the carb. I bought the low elbow but still needs some lift.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've always done it that way with no problems. The thicker gasket is probably better since it gives the carb more insulation from the heat of the intake.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
