Spacer???
Old Jul 8, 2005 | 08:49 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
Spacer???
I know that spacers are said to be "tuning tools." But I was wondeirng if i should use one on my setup, and if so which one? I dont have the money to buy multiple ones, so if I can pnly get one, which one should I get for my setup? Thanks.
Old Jul 9, 2005 | 03:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock what heads?
What's the duration of the cam?
Which Weiand intake?
What do you use the car for? What are your goals with it?
Old Jul 9, 2005 | 07:19 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Given the small specs of the cam lift I'll assume the actual duration is on the small side and the rest of the combo leads to more off idle low rpm powerband. I would stick with a 1" 4 hole spacer. Any taller and you run into clearance problems and the 4 hole design lends itself to boosting low rpm power. Some engine take really well to them, other dont. Meaning some may feel stronger seat of the pants, buyt not show anything at a track, only for sure method is a dyno session.
Just remember, putting a spacer between the carb and intake is never a bad thing since it helps control heat sink somewhat which in turns helps fuel delivery into the plenium.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
