backfiring through carb, ive tried everything
Car: 1991 camaro RS
Engine: 305 Carb
well ive had my TBI to Carb swap done for some time now. I swapped to a edelbrock 600 carb #1406. I have the timing set at 14 degrees advances, ive checked the plug wires to make sure there in the right order 150 times. all the vacuum is hooked up. I cant figure this one out. It doesnt not do it very much at all, its like i have to try. and it only happens if i rev the engine, let the RPM's drop and then stomp it all at once again. Im runng 6 PSI of fuel pressure, is this too much? Even if it is it wouldnt cause this would it?
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
your fuel pressure and timing are about right. Problem could be the carb is leaning out when you rev it. I don't know too much about edelbrocks though so I can't really help you there. If you can check the float level on the carb and see if the bowls are running dry.
Car: 1991 camaro RS
Engine: 305 Carb
Ok well let me ask you this, i dont have the carb completely tuned yet. COuld this be it? Im gonna get a vacuum gauge and adjust the idle mixture screws. The distributor is hooked up to the carb
2012sergen11
Oct 13, 2015 07:38 PM
Damon
Sep 26, 2015 04:29 PM
