Mallory 4309 Leaking
Old Jul 13, 2005 | 01:37 PM
weigesco's Avatar
Car: 89 RS Convertible
Engine: 350 Carbed, No Computer
I switched from TBI to carb about 2 months ago. I am running the Mallory 4309 Fuel Pressure regulator. I have everything connected and it has been working ok. Last week I noticed that fuel has started to leak out of the Boost Port on the regulator. Could this be a bad diaphram in the Regulator? It seems to hold pressure fine at 4psi. I can adust the pressure up and down fine but still have gas coming out of the boost port. Any help is appreciated.
Old Jul 13, 2005 | 04:02 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Sounds like the diaphragm is torn.
Jegs carries new ones #3156 at $25 IIRC
Old Jul 17, 2005 | 10:44 PM
weigesco's Avatar
Thanks for the response. I checked the diaphragm and it was leaking. I got a new one from Summit. Just as an FYI for everybody. The new diaphragm is a little different and I needed to make up a spring to get the pressure under 10 psi. I think maybe the spring that was in it before was the high pressure spring but the diaphragm was always leaking so I could get the pressure down to 5 psi. Mallory says that the new diaphragm will not work for 12-60 psi any longer. Thanks.
RS Reaper
Oct 17, 2018 07:52 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
