Should i make adjustments to new edelbrock carb
Old Jul 16, 2005 | 06:45 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I have recently completed my TBI to Carb swapped and i finally getting her up and running right. Im running an edelbrock 1406 carb brand new and i was wondering if i should make any adjustments to it as far as the choke, floats and metering rods or anything else. basically what im wondering is if there built ready to use on any setup right out of the box
Old Jul 16, 2005 | 06:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No carb comes tuned for your car out of the box. Usually they'll be set up sothat the cra will at least start and run, but they always need tuning.
Old Jul 16, 2005 | 09:19 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
So should i adjust the floats? Also should i buy some metering rods, how do i know which ones to buy?
Old Jul 17, 2005 | 02:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Always check the floats before you install the carb. They're set from the factory, but bouncing around during shipping can change things. The only way to know what jetting you'll need is to run the carb with the factory setup, see if it's rich or lean, and go from there. The Edelbrock manual covers the whole process pretty well.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
matthew911
Aug 12, 2015 09:38 AM
