Code 21
Old Jul 20, 2005 | 07:26 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
Code 21
I recently took off the airhorn of my Q-Jet to replace some bits under there, and now I'm throwing Code 21: High voltage at TPS. I searched a bit, and discovered it's easy to re-install wrong. My guess is that this is what I did. Would a bad TPS install throw code 21?
Old Jul 20, 2005 | 09:49 PM
Vader's Avatar
Once it is installed, you'll need to use your adjusting tool to lower the TPS preset to something under 0.65V. 0.48V is the common setting at the hot idle position.
Old Jul 20, 2005 | 10:26 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Ah, ok. So I need to readjust it, even though it's the same one I took out? Where can I acquire said tool?
EDIT: Could you also point me towards some information on setting the TPS preset? Is it referred to by another name/phrase? I saw some stuff about setting the M/C solenoid in the book I was working with, but didn't see anything about the TPS. THanks!
Old Jul 23, 2005 | 09:02 AM
Vader's Avatar
The tool kit you will need is OTC 7667. It contains all the special bits and sockets necessary to adjust the mixture stops, remove/install jets, adjust the TPS, and set up any E4ME/MC. E2SE, Varajet, and several other Rochester carbs. The set is about $12-15.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
