got a question?
Old Jul 30, 2005 | 12:08 AM
alxtre99's Avatar
Car: 91' Camaro, 71' MERCEDES
Engine: Camaro 3.1L
got a question?
i have a stock q-jet in my T/A and when i open her up at full throtle she sounds like a damn vaccum cleaner, i'm assuming it's the secondares opening up but i had a camaro that had the same carb but she didn't sound like that... i was wondering if it's just dirty or is that perfectly normal; i was told the carb was brand new when i bought my car, and that was like 3 months ago, but it sounded like that when i first bought my car, any thoughs or opinions?
Old Jul 30, 2005 | 12:14 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
most of my q-jets sounded like that
does it run okay? if so, don't worry too much
Old Jul 30, 2005 | 12:18 AM
alxtre99's Avatar
Engine: Camaro 3.1L
there seems to be a lil' lag at full throttle, i was told to advance the timeing a lil', and im also no carb expert, what do u think?
Old Jul 30, 2005 | 12:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Make sure the ignition is up to snuff first.
Then, you may have an issue with the secondary air valve opening too quickly. The choke pull-off holds the AV closed until vacuum drops, and the AV has an adjustable tension to get them to open at the proper time. Both need to be working right to avoid the bog.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
