Changing from Fuel injection to Carb, anyway I can get around NOT changing fuel pump?
Old Jul 24, 2005 | 12:27 PM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
Holy heck, installing my fuel pump nearly killed me mentally, and I don't think I can go through all that again.
Is there anyway I can get around having to do that again
Old Jul 24, 2005 | 12:28 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Sure, it doesnt have to be changed. All you have to do i buy a return style regulator and tone the pressure down to 5 or 6 PSI. I have just made the swap myself
Old Jul 24, 2005 | 01:25 PM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
The regulator controls the pressure for me? So I would not have to change fuel lines or anything?
Your the man, I think this swap might do the trick
Old Jul 24, 2005 | 11:11 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
You probably will have to reroute your lines a bit,and be sure to do a clean,thorough job plumbing in the regulator,nobody likes a burning car.
Old Jul 25, 2005 | 04:32 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Yea this is true, but its not hard, i mounted my regulator on the strut tower right near the fuel lines where the rubber lines are. worked great, if you want i can send you a picture
Old Jul 25, 2005 | 11:12 PM
Muirner's Avatar
Car: 89 Camaro RS
Engine: 86 Monty 305 .030 over
post the pic on here, sounds cool
Muirner
Old Jul 26, 2005 | 06:35 PM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
I would really like to see, you can post here or pm me!
Thanks in advance,
Meatwad
Old Jul 27, 2005 | 12:17 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Here ya go man, as you can see in the picture, i took the rubber lines and cut the metal fittings off them and just connected them to the regulator, then just ran the line over to the carb. Hope this helps:
Attached Thumbnails Changing from Fuel injection to Carb, anyway I can get around NOT changing fuel pump?-fuel-lines.jpg
Old Jul 30, 2005 | 11:39 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Here's mine on my '88 GTA. Bypass regulator JEGS part #793-30-900. It reuses the original hoses that went to the TPI engine. Notice the armor on the hoses and double clamps. I give a big AMEN on the "burning car" statement.
AW.
Attached Thumbnails Changing from Fuel injection to Carb, anyway I can get around NOT changing fuel pump?-100_0405_6.jpg
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
