Best carb for my application?
Hey guys,
I have an 81 TransAm (used to have an 82). I dropped in a 350 4-bolt from a 1974 Impala, with 1971 Corvette, 76cc heads, 2.02:1 intake and 1.6:! exhaust.
I have no idea what cam I should go with, and I don't know what's in there now (another post for another tech board).
With those kinds of cyl heads, and that displacement... I plan on going with a cam that will produce power primarily in the MID-RPM range... with a tendancy more towards the low-RPM torque.
With that in mind, will a 600CFM carburetor be sufficient to power this motor? I have a 780 (??) Rochester NON-CC Carburetor I could use, or my Edelbrock 1405(7??) 600CFM carburetor with electric choke.
I tend to want to use the Edelbrock, but then I have to use a spacer and adaptor and it screws up the shaker on the hood... I'd prefer to use the Rochester, but I don't know if I can get as much power from it?
Any help is appreciated.
Thanks!!!
Thanks!!!
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
the rochester will work, but idle may be an issue, and for sure it will have bogging issues...
your right on the size - a 600-650 would be fine to support the rpm your going to be running with that motor... i guess which style carb you want to use is up to you, i prefer holleys, but plenty of people have no trouble with the edlebrocks either..
2012sergen11
Oct 13, 2015 07:38 PM
Damon
Sep 26, 2015 04:29 PM
