Fuel line
Old Sep 2, 2005 | 08:56 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Fuel line
I want to install a carb spacer I have. If I install it though, the fuel line that goes into the carb/fuel filter will be too short and wont reach. I have the stock q-jet carb. Where can I get a replacement fuel line? Im not sure what size I would need also.
Old Sep 2, 2005 | 08:53 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Also would it be better to start using an inline fuel filter?
Old Sep 4, 2005 | 08:40 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Using an inline fuel filter is a good idea. Just don't use a plastic one. When you put hose in place of the metal tube, resist the temptation of hacksawing off the ends of the tubing and using them instead of barb fittings. A 3/8" stream of gas will make an inferno of a fire.
Old Sep 7, 2005 | 04:18 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Does anyone know the size of the fitting I will need for the fuel pump? This fitting should work for my q-jet right?
Old Sep 12, 2005 | 06:17 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Ok this is what I will be going with. Im also going to be putting an inline filter in there. Do the sizes look right? Just want to make sure before I order the stuff.
Carb fuel inlet fitting
Fuel inlet fitting to line
Braided line
Line to fuel pump fitting
Fuel pump fitting
Old Sep 12, 2005 | 06:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Aeroquip has a kit that includes all the fittings and hose-ends and hose to run from the pump to the carb, it should be a little less expensive than buying everything individually. You could just add two more hose-ends and a filter.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
