Which power valve?
Old Sep 4, 2005 | 01:49 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Which power valve?
Trying to determine if my power valve is the right one or not. I am using 4.5's and I checked my vac. At idle it's at 5inches. Under load it runs 7 inches and full throttle 0 inches. I seem to be blowing a couple valves now and again on my 780cfm holley. Is there more info I am missing here to help with this question? I have a huge cam that allows almost no vac which is why I have a vac reservoir for the power brakes.
Old Sep 4, 2005 | 08:37 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If the 5" at idle is with motor warmed up and in gear, you need a 2.5 PV
Old Sep 5, 2005 | 01:23 AM
2.5? Why is that. I was thinking more on the line of 4.0 from 4.5. I drove the car with the gauge taped to the window and my son took readings. We checked and double checked. Idle in gear was 5, on the throttle was 7/8 and wide open was 0...Thanks for the help.
Old Sep 5, 2005 | 02:52 AM
IHI's Avatar
IHI
PV does'nt mean squat once you past 1/4 throttle. To get the right PV you take what you vacuum is in gear with motor warmed up and divide it by 2.
Why your going through multiple PV's is beyond me I've run multiple carbs and this current 950HP for 4 years straight and have'nt lost 1 single PV yet.
If it's truely 5" at idle in gear- warmed up, trust me, buy the 2.5" PV's., set your idle mixture screws and get on with more important things.
Old Sep 6, 2005 | 01:31 AM
Ok, cool. I appreciate the help.
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
g.l.mos
Aug 22, 2015 12:02 AM
