switching to carb ?'s
Old Sep 8, 2005 | 08:34 AM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
well i am back in the states now and working on getting everything ready to drop in my 406...my father in law who owns his own shop is doing the work and was thinking of using the stock sending unit from the gas tank and just putting on a different regulator. this got me thinking and i know the psi on my tpi was set at 42 and carb's only run 6-8...so has anyone used the tpi set up or do we need to swap everything over to an eng driven pump? and will we need to swap fule lines also? thanks dave.
Old Sep 8, 2005 | 10:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moving this to the Carb forum.
Oft discussed here. You'll need a return-style regulator (about $75, typically), that can be set down to 4-6 psi. The in-tank pump needs constant flow, which the return provides, in order to keep it from overheating.
You don't need to change fuel lines, just reroute them in the engine compartment.
Old Sep 9, 2005 | 08:31 AM
Car: 87 iroc
Engine: 410 sbc
thanks, does anyone have any more suggestions???
Old Sep 9, 2005 | 10:15 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I posted pics & info on my setup here.
I don't know if the stock pump can supply 500+hp worth of flow.
If you could come up with the GPM @ 6psi for that much power, I could do a flow test and tell you for sure.
Old Sep 9, 2005 | 11:50 PM
Car: 87 iroc
Engine: 410 sbc
i will end up running an in-line pump most likely and not actually the in-tank..i believe that should supply enough???
MustangBeater20
Oct 29, 2022 09:20 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
