edelbrock???
Old Sep 9, 2005 | 10:05 AM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
edelbrock???
Ok, heres the deal, i have a 1982 Camaro, 3.73 posi rear, th350 trans with shift kit and 3500 stall, 355 SBC with world sr torquer 2.02 heads, 10-1 comp, .530 lift cam 30/30 cam, 1.6-1 roller tip rockers, mallory ignition, flowmaster exhaust with holley shorty headers, currently a 750 cfm Edelbrock,
I took it to the trak last week and ran a 14.6 with a 1.90 60', it wouldnt pull at top end, so i put a single plane intake on it to help and because i suspected a vac leak. now i can turn my air/fuel screws anyway i want with no change, idle doesnt go up or down, wouldnt this suggest i have a vac leak?? shouldnt the engine die when i closed these screws?? this car is makeing me pull my hair out and just doesnt have the power it should
Russell
Old Sep 9, 2005 | 10:07 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yes it should start to miss when the screws are too far in or out (lean/rich). I have had a hella time setting mine up nicely and after a whole summer i still think it can do better.
My next buildup is getting a holley or something...
Old Sep 14, 2005 | 08:29 PM
camaro03's Avatar
Car: 1982 camaro
yeah i can put them all the way in without a noticable difference
Russell
Old Sep 14, 2005 | 10:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is the choke open or closed when you do that?
Old Sep 15, 2005 | 11:53 PM
camaro03's Avatar
Car: 1982 camaro
its open
Old Sep 16, 2005 | 12:55 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
which edelbrock carb ?
did you check to see if the metering rods are sitting in the seats right? Floats adjusted right etc....
Old Sep 16, 2005 | 06:42 AM
contact's Avatar
Engine: sbc 350
camaro03,
can you get your hands on a vacuum guage?
if so, you might try this test,
hook it up to look a nanifold vacuum when driving.
at WOT, vacuum should be, guessing, 3 psi or less..
if you have lots of vacuum at WOT, there is
some kind of a restriction.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
