holley guys..strange prob, please help?
Old Sep 13, 2005 | 08:11 PM
raceb8's Avatar
Car: 89 rs
Engine: 355
Transmission: th350
Axle/Gears: 4.56 posi
o.k., the camaro was running great w/ the original carb, then it started to flood out after shutting off & not want to start. decided to rebuild it, but couldn't do it in one day, so i put on an 850 dp (#9380) that i had just rebuilt. really woke up the motor!! but, i have a strange bog at about 3000 rpm, half throttle, like cylinders are cutting out? #76 jets in front, #80 in rear, front power valve 3.5, rear valve plugged.(it also did this w/ a 3.5 in the rear) timing is dead on, 22* initial, 35 total, all in by 3000, just like w? other carb. any ideas?
new carb has annular boosters, old had downleg
also, the 850 doesn,t want to idle all the time? too little stall for the big carb?(currently 2200 stall)
Old Sep 16, 2005 | 08:38 AM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
you can find any info on holley carbs on the web site www.holley.com I have found it to be very helpfull. If yo urun a holley........ hope you tinkering.
Old Sep 16, 2005 | 12:33 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
any idea what kind of vacuum you are pulling at idle?
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
