fuel pump?
Old Sep 13, 2005 | 09:49 PM
ephen's Avatar
Car: 85' Camaro Berlinetta
Engine: 2.8 L
Transmission: M5
fuel pump?
if im switching to a carb from fuel injected i know ill have to get lower fuel pressure. can this be done with regulator or do i have to switch fuel pumps to a lowed psi one and take the old one out of gas tank?
any info on this switch is appreciated
thanks
Old Sep 13, 2005 | 09:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can use a return style regulator with the in-tank pump. If you do a search, this has been covered in detail a number of times.
Old Sep 13, 2005 | 10:14 PM
ephen's Avatar
Engine: 2.8 L
Transmission: M5
ok thanks i just wanted to clarify cause i had a mechanic tell me there was no way to regulate the 50 psi down to 4
Old Sep 14, 2005 | 12:32 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
A Mallory #4309 will do exaclty that.
Like Apeiron stated..search on it..a ton of info!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
