How to make a lean mixture
Old Sep 19, 2005 | 09:59 PM
cuda71ss's Avatar
Car: 1986 Chevy Camaro
Engine: 5.7L 350
I have a 350 with a Holley 650 on it and it runs pretty rich. Is it true that when the air/fuel mixture screws are all the way tightened/in that the mixutre should be lean? What all comes into play in able to get a lean mixture?
Old Sep 19, 2005 | 10:42 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
If you're still running rich with the idle mixture screws turned all the way in, the screws are not your problem. Possible causes are the fuel pressure(too high), or the float levels(too high). Check your fuel pressure and float levels. Once you have found the problem and corrected it, set the idle mixture screws 2 1/2 turns out and tune from there.
Old Sep 19, 2005 | 10:55 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ditto. Something's wrong on the inside.
Old Sep 20, 2005 | 02:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You do understand that those mixture screws are for the idle only...
Old Sep 20, 2005 | 11:00 PM
cuda71ss's Avatar
Engine: 5.7L 350
Thanks guys
theshackle
Sep 17, 2020 08:26 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
billybob6110
Sep 24, 2016 09:50 AM
cougar20th
Aug 27, 2015 08:04 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
