Carb adjustment
Old Oct 4, 2005 | 06:56 PM
MorbidHobo's Avatar
Car: 1983 Z-28
Engine: 5.0 305 4bbl
Transmission: M5
Carb adjustment
Does anyone know what the proper adjustment would be for a rochester e4me q-jet 4 bbl carb would be? i cant seem to get the lean or rich mixture screws right. any help would be appreciated.
Old Oct 4, 2005 | 07:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What adjustment resources do you have at your disposal?
Old Oct 4, 2005 | 08:41 PM
Damon's Avatar
When I set them on the bench I set them the following way and ONLY in the following order:
1. Lean stop 4 turns up from lightly seated.
2. Rich stop adjusted to allow exactly 1/8" of travel between rich and lean stops. Obviously, you must set the lean stop first. If you don't know how to check for total travel shoot me an email.
3. IAB screw set 4 turns up from lightly seated.
4. Idle mixture screws usually about 4-5 turns out for most stock V8 applications. Little more for a performance-modified motor.
5. TPS adjusted on the car once a stable spec idle has been established on a fully warmed up running engine.
That'll usually get you in the ballpark on anything with a small block V8.
Old Oct 7, 2005 | 01:53 PM
MorbidHobo's Avatar
Car: 1983 Z-28
Transmission: M5
Yeah about that. I just had the thing rebuilt and now its stuck ideling at about 2000-2500 rpm. It also slowly increases as the car warms up. I will try what you said though Damon.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
makaveli09
Sep 15, 2015 10:43 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
