Fuel Filter Carb Swap
Old Oct 5, 2005 | 12:40 PM
Jalapeno's Avatar
Car: 1987 IROC Z-28
Engine: 350 Bored .40 Over, Vortec Heads, Comp Cams XE 268, Comp Cams 1.6 Magnum Roller Tip Rockers, Edelbrok RPM Air Gap Intake, Demon 750 Mech Secondaries, Electric Water Pump, March Pulleys
Transmission: TH700r4
I am about to install my new inline Holley Blue electric fuel pump. My question is, is there any reason I have to remove the old canister filter, if I put the new fuel pump between the canister and the tank? Does a Holley Blue pump hard enough to push through the canister filter and supply adequate fuel?
Old Oct 5, 2005 | 04:25 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I don't think you will have a problem.
Old Oct 5, 2005 | 06:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The way you described installing it wouldn't be a problem at all.
Are you taking out the original in-tank electric pump?
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
