still idling high
Car: 1987 camaro lt
Engine: 305 4 barrel
Transmission: th 700r4
still idling high
checked all vacumn lines set timing but at startupthe rpms are very high after a couple of minutes i hit the accelerator quick and the idle drops to normal,i know my choke pulloff is bad and needs to be replaced,would that be a cause of a high idle at startup?
Car: 1983 Z-28
Engine: 5.0 305 4bbl
Transmission: M5
i had the same problem and as soon as i got a new choke pull off it fixed a multitude of problems including yours. If you do anything take naf's advice and get that part before doing anything more.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
