650 speed demon issue
Old Oct 14, 2005 | 12:26 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Has anyone ever experienced a bit of gas coming out of the full manifold port on the speed demon carb? not alot but enough that when i pull the vaccum cap of it's wet.
the floats seem ok maybe a tade low but defiantly not high
Old Oct 14, 2005 | 01:20 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
perhaps there is a bad gasket or o-ring in it allowing gas to seep between the mettering block(s)?
Old Nov 2, 2005 | 04:59 PM
az_brent's Avatar
Car: 1985 firebird s/e
Engine: 388ci stroker
Transmission: stock, t-5?
i have the same carb and when i got it the only problem i had at first was the fuel viewer leaked but only till it preasureized then it stopped leaking..id agree either bad gasket or o-ring..call the guys as demon and tell em bout it and see what they have to say....if you already havent taken care of the problem
Old Nov 2, 2005 | 07:57 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Somethings wrong with it... Take off the fuel bowls and metering blocks and replace those horribly crappy red gaskets with the blue Holley non-stick ones. Problem solved, forever.
Street Lethal
Apr 30, 2019 12:14 PM
deracer
Apr 11, 2016 12:04 AM
destroyerwes
Aug 26, 2015 08:17 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
jbd1969
Aug 17, 2015 07:06 PM
