choke cable
Old Nov 12, 2005 | 04:08 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
choke cable
I'm having trouble running a choke cable. what do you guys use? I have choke cable and it closes the choke, but when I push it in to open it the cable housing just flexes and nothing opens
Old Nov 12, 2005 | 07:18 PM
84camaroZ's Avatar
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
Re: choke cable
maybe too much slack in the line?
Old Nov 13, 2005 | 12:37 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
I had the same prolem due to where I put the choke control (under the dash next to the diagnostic port). The trick I found is to "preload" the cable a little, so that fully open the control has 1/4" to 3/8" of rod stil extending. This allows you to give the cable the extra push it needs to open back up after start up. Another thing you might try is using a shorter cable and grasing the it by removing it from the housingand running it through a greaced rag.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
