Is there enough room to tap the top of the fuel sender?
Old Nov 13, 2005 | 02:43 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Is there enough room between the top of the sender on the fuel tank and the body to tap it and install a 90* fitting to run a -8AN line out of the top of the tank? I planned on using a 1/2"npt to -8an 90* fitting out of the top of the tank and get rid of the 3/8" rubber line. I've done it on a coule 4th gens but the tanks are a little different and don't know if there's the same amount of room for it on a thirdgen. FIgured it would be a better alternative to getting a new tank and welding a sump to it.
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
