K&n
Old Jan 4, 2006 | 03:27 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
K&n
Has anyone used or seen the k&n filter on a carb w/the filter that goes all around and ON TOP? trying to find one, seen one in chevy hi-po mag but nothing was mentioned about it.
Old Jan 4, 2006 | 03:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
heard of those, called the 360 or something? or xstream?
bad thing is your hood sits right on top of it, negating any good effects of the air cleaner part on the top.
Old Jan 4, 2006 | 03:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
http://store.summitracing.com/defaul...=egnsearch.asp
first two on the list.
K&N calls them Stream Air Flow Top Plates.
just FYI. you need to run a tall filter with these.
otherwise, the pleats on the top come close to the carb, and you get some "intresting" carb responce... just because it clears without touching, doesnt mean its enough space... give it atleast a half inch...
otherwise, you're better off not running one.
Old Jan 4, 2006 | 06:22 PM
w1964bgta's Avatar
tgo rules
Once again the knowledge on this site never ceases to amaze, you guys rule thanks alot
Old Jan 5, 2006 | 01:05 PM
w1964bgta's Avatar
mrdude
Hey just wondering what kind of interesting carb response?
Just so I'll know what to look or listen for apon start up if I
made some dumb move, thanks
Old Jan 5, 2006 | 01:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not only that but those things probably aren't going to do anything useful when they're jammed right up against the hood insulation already.
Old Jan 5, 2006 | 01:15 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: mrdude
you get this wierd stumble that you cant tune out... usually when going to WOT..
you'll spend hours on the stupid pumpshot, and even mess with the jetting, and never get rid of it... or if you do, then it drives like *** the rest of the time...
frankly IMO, unless you have a cowl hood, skip it and run the largest filter you can.. drop base and all...
if you do have a cowl..... you're still better off running a taller airfliter, then leaving it low and putting that on.
if you had a older truck or something with alot of room, then by all means get it.. it looks cool... but i wouldnt add one to my car.
Old Jan 5, 2006 | 01:16 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i always take the insulation off....
Old Jan 6, 2006 | 01:59 PM
rjmcgee's Avatar
I have the regular 14 x 3 K&N with out the fancy lid. While on the chassis dyno I removed it for the second pull and lost 1 hp. Might save your $40 or so and buy something else for the car.
Old Jan 12, 2006 | 12:49 PM
4MULA88's Avatar
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
Got it from Jegs.
Old Jan 13, 2006 | 12:18 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Yea i believe its called the xstream. Also 4MULA88, do you have any hood clearance problems with that set up you have.
Old Jan 15, 2006 | 04:53 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
my buddy went to school at UTI. He told me they did a test on them to see what power gains you get from them and they actually lost power with it. Could have just been the type of car or motor, but i wouldn't wast my money on one.
Old Jan 15, 2006 | 05:01 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Yea i have heard that you loose power because of them to, so im not going to spend the money.
Old Jan 17, 2006 | 05:49 PM
4MULA88's Avatar
I am running a 14x2 drop base with the lid. The only thing I had to do was a little dolley work to one of the hood braces on the stock 83 Ta hood. I also have the factory duct work removed so I am pulling air through the scoop.
Old Jan 18, 2006 | 02:59 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Well im thinking about running the same setup under the stock hood.
Old Jan 31, 2006 | 08:01 AM
w1964bgta's Avatar
Hey 4mula88 do you have any pics of your setup? Would like to see'em
Old Feb 8, 2006 | 06:17 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I have a K&N with the Extreme Flow Lid.
Gained 5 HP on the dyno by taking it off.
Old Feb 9, 2006 | 10:50 AM
19kilo's Avatar
Car: 1985 Z-28 2003 chevy Silverado Z71
Engine: was 305 LG4 now 355 HO
Transmission: TH700r4
Axle/Gears: posi 373
I use it and it looks good i say get it.
