holley 650 vacume help
Car: 84 z28
Engine: 305 h.o 4bbl
Transmission: t5
im switching out a ecm controled q-jet for a holley. i caint figure out where to hook my brake power booster to. there is no port in the rear of the carb like q-jet/elderbrock. the holley has only 2 other ports one at the base of carb for the vacume advance and one behind the front float bowl. i guess its not a carb question but what kinda vacume does the brake power booster require ported i assume ?
Transmission: 4L80E/4L80E
The brake power booster requires full manifold vacuum and a fairly healthy-sized line. The factory uses 3/8", you should do the same.
Unless this is a double-pumper carb, you really shouldn't change from the factory q-jet.
RaverRacerX
Mar 17, 2026 01:49 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
