quad to tpi
Old Jan 19, 2006 | 06:32 AM
rtchaney's Avatar
Car: 89 RS
Transmission: Auto w/ evil shift kit; not my doin
Axle/Gears: It has a locker; not my doing
quad to tpi
ok.. i know its a pain but, i don't have an smog or air system. any problems that could arise out of that with the computer trying to adjust any thing? also, any good guesses on what size injecters to put on a 427sbc?
Old Jan 19, 2006 | 10:29 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
A quadtrajet computer cannot control TPI. Simple matter of function. Every sensor, ECM, fuel pump, there's more to change that I would be willing to go through.
I wouldn't use a TPI on a 427, either.
Old Jan 19, 2006 | 12:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Putting TPI on a 427 would be about the same (performace wise) as putting a 2bbl carb on a 427. If you wanna go fast, it just won't work.
The CC Qjet on the 427 could be VERY cool though
But since the 427 is based on a 400 block, would the knock sensor from a 350 work? The bores are 1/8" different...?
If the knock sensor would work, then I'd say go that way. That would be a really hot street mill
Old Jan 26, 2006 | 04:55 PM
rtchaney's Avatar
Car: 89 RS
I was planning on getting a "Painless Wiring Harness" and ECM for a TPI system. But, i read that by removing the smog pump that a Tpi based car tries to compensate for the temp and air fuel %; thus, stuff gets broke. so, i wanted to know what to do to the ecm so it wouldn't try to alter because of the lack of smog pump. that quad on a 427 does sond pretty cool.
Jeremys87
Jul 14, 2022 09:08 PM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
