MPFI to carb
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
MPFI to carb
I have an '89 RS with a 2.8L MPFI engine. I am planning on swapping in a crate 350 with carburated induction. Will my electric in-tank fuel pump supply enough gas to the carb? Too much? Will I need a pressure regulator?
Transmission: 4L80E/4L80E
You will need a pressure regulator. Get one that regulates pressure with a return port. They are more expensive than the dead-head ones, but your pump needs the return in order to have a good long life. I have seen someone use a dead-head regulator with a retun line adjusted with a needle valve - it's just simplier and more exact to use a return style reg.
The pump may or may not keep up with the engine, depending upon the engine you end up getting and the condition of the pump. In good condition, a stock pump can keep up with most streetable NA carbureted engines.
I'm planning on going with the Plain-Jane Goodwrench replacement 350 with a 650 cfm carb, not sure about the carb selection yet, but something fairly mild.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
