Intake Questoin/Suggestions
Old Feb 11, 2006 | 04:21 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
I've got a 350 that i'm switching from EFI to Carb I was just wondering what intake is working good for you carb guys
I got a .465/.488 cam i'm going to put 1.6 rockers on it at some point in time...i have a 3.73 gear and a T-5 trans
If you need any other info just post back...oh and i got no carb so if you could give me a suggestion on a carb to that would be great...Thanks for the help
Old Feb 11, 2006 | 04:29 PM
Car: Trans Am
Oh i also got a high rise hood, so i'm not scared of goign with a high rise manifold
Attached Thumbnails Intake Questoin/Suggestions-100_0926-smaller-1.jpg
Old Feb 11, 2006 | 08:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Edelbrock performer RPM, air gap if you have the extra $$
weiand stealth is pretty well liked too.
I like my Q-jet, non-cc., due to the fact I can get them from the JY for $20, and a rebuild kit for $40, and i'm set. Extremely tuneable, and you get to brag to people you have a q-jet (everyone has a holley, you're nothing special bragging about having a holley)
Old Feb 11, 2006 | 10:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ditto the RPM recommendations.
I considered the Stealth, liked the Air Gap concept (even if not quantified back-to-back with non-AG type), so went with it instead.
Old Feb 11, 2006 | 10:05 PM
five7kid's Avatar
Oh, I don't believe the Air Gap is available in a spread bore configuration. So, if you go with that and a q-jet, you'll need an adapter.
Old Feb 12, 2006 | 11:24 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm happy with the Performer RPM. If your not into your own carb rebuilds, an Edlebrock 1406 can be had at Pep Boys brand new for $290, and it (usually) runs straight out of the box - no adjustments (initially) or adapter needed as it is square bored like the Performer intake. Also keep an eye on the classifieds here - 1406's pop up all the time for cheap, as everyone wants to move up to a Holley.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
