Electric To Manual Fuel Pump
Old Mar 26, 2006 | 08:15 PM
Joker's Avatar
On Probation
Car: 87 Pont Firebird
Engine: 305 Carb
I Installed a replacement 305 that was once an Electic type Fuel Pump. When I went to convert it to a manual Fuel Pump I pull the cover off the side of the engine and found some type of plug in the hole that the Pump Shaft is located. Is this just a plug I can pull out and replace with a Pump Shaft rod. I would leave the Electric Pump I put on, but I'm finding it to me a lot of up keep (not to mention load).
Old Mar 27, 2006 | 09:39 AM
Damon's Avatar
Somewhere in the late 80s/erly 90s they produced blocks that no longer had the fuel pump pushrod hole machined into it. Also, even if it had the hole the (stock?) cam in those engines often did not have the fuel pump eccentric machined into the cam
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
