lg4 in tank fuel pump upgrade
Old Apr 2, 2006 | 10:27 PM
anthony714's Avatar
ok,i started with a stock lg4,now its a healthy stroker.my ? is fuel supply.im going to run a hig volume mechaincal pump but i need to knowif i need to upgrade the intak electrical pump or is it sufficent?will it hinder th esupply?if i need to upgrade where?who makes one.i see the zz24 upgrade had a new pump bt i cant seem to find that part anymore.help please.like i sai dthis is a healthy engine so shell need to slurp fuel
Old Apr 3, 2006 | 01:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
As long as the pump is in good condition it should push fuel to the mechanical just fine.
Old Apr 6, 2006 | 09:18 AM
Damon's Avatar
If it's working it will probably do just fine. When they cut out, however, the engine keeps running just on the mechanical. You have to make sure it's actually getting voltage and actually pushing fuel. Not easy to tell when they die.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
