non cc q-jet on new 350
Old Apr 2, 2006 | 08:02 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guy i just finished rebuilding a 350 (lo5) new bearings seals etc
here are the vitals
stock 9.3 compression
ported and polished 193 swirl ports 1.94/1.5 back-cut valves and 3 angle valve job
lt1 cam shaft and lifters (used) roller
comp 981 valve springs
melling m55hv oil pump
anyway i rebuilt a non cc q-jet last year
carb # 7045203-2065
1975 camaro
anyway i rebuilt it and had it on the old 305 but it ran pretty rich
does anyone know a baseline type hanger/ rod combo that would work well as a starting point??
Old Apr 2, 2006 | 09:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you're ahead of me a bit
that's not an overly aggressive motor so, I think you're ok with say;
43 rods
73-74 jets
for primaries, and for secondaries, any hanger you want. use DR rods.
check what primary rods and jets there were in there, I think the '75 q-jet would have the older style primary rods, and not the '74 and earlier longer ones... ( well, should, but maybe not...)
make sure your AV is tight, and not flopping around. probably just needs to be tuned nicely, ie primary power plunger height set right, float set right, idle mixture screws set right. not rocket science, but make sure all your basics are set up right before you chase a different problem.
good luck.
Old Apr 2, 2006 | 09:13 PM
1984HO's Avatar
Car: 1984 Z28
thanks sonix
just out of curiosity do you know a place where i can get hangers and rods and jets if i need them??
Old Apr 6, 2006 | 10:25 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
You could try carbs unlimited, or the junkyard.
I ran 46 rods / 76 jets on my ZZ4, so you probably want less than that.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
