Installing Jets
Car: 89 Camaro
Engine: 408ci sb, 195AFRs, 750 Mighty Demon
Transmission: JW Full Manual Valve Body TH350
Installing Jets
I'm wondering if anyone can help guide me in the right direction on how to install different carb jets? I know basics about tuning but I have not yet had to change out jets.
I just purchased a 750 mighty Demon carb and it seems to be running a little rich on my setup. To correct this I would like to decrease the jet size and see if that will take care of the problem.
If anyone can help me out I would really appreciate it. Or if anyone knows of a website where they have pictures of the process that would also be very helpful.
Transmission: 4L80E/4L80E
Welcome aboard TGO!
You have to remove the fuel bowls. Each bowl is held on by 4 bolts (take the fuel line off first, of course). The jets are in the metering block behind the bowl.
Steps of 2 jet numbers at a time (for instance, from 76 to 74) are recommended.
Car: 89 Camaro
Thanks!
Are there any tricks to taking the fuel bowls off and putting them back together or is it really straight forward?
Thanks for the help
Thanks for the help
When you remove the first bottom bolt from the bowl, that bowl will drain. Good idea to have something under it to catch the fuel. You can get a fancy little cup that has a chute on it to go under the bolt, or you can cut a tin can short enough to fit under it. Whatever turns your crank.
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
I also need to jet my Holley 750 cfm vacc secondary carb. How do I know what jets to start with and when to stop?
Engine: 400
Five7, thanks for the site, I will check it out. The car backfires badly when I get on it and the left off. I have been told by several people it needs to be jetted? If I recall correctly when I pulled the plugs they were blackened = too much fuel
. The motor was in a truck and I'm in the process of putting it in my Camaro. We'll have to see what happens. Thanks again. Later
-Greg
. The motor was in a truck and I'm in the process of putting it in my Camaro. We'll have to see what happens. Thanks again. Later-Greg
Car: 89 Camaro
Just wanted to say I got the new jets in, went down two sizes on the primary and secondary and the car seems to be running excelent.
Tomorrow I will have to take it out for a spin and see how it runs on the road!
Thanks for the help!
colton_carlson
Mar 8, 2019 12:21 PM
gixxer92
Sep 1, 2015 04:32 PM
