fuel pump question
Old May 19, 2006 | 08:20 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
fuel pump question
the fuel pump that bolts on to the block is that suppost to have 2 bolts or 4 bolts...I have a 1988 block and i'm going to run a mechical fuel pump.
As I need to have the fuel pick up installed. i'm goign to do that myself...auto or anyone else for that matter doesn't sell it...does anyone know where i could get one...besides the junk yard....
PLEASE GIVE ME REAL ANSWERS...lately i've been posted stuff and i'm getting the dumbest feedback
thanks
Old May 19, 2006 | 09:35 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
dumbest feedback
You only get back what you put into it. Do a search instead of asking others to do your research.
The fuel pump itself is held in with 2 bolts the plate under it is held in with 4 thats including the two holding down the pump.
For the pick up.. did you try your local gm dealer or a napa? Try online too from gmpartsdirect website.
not sure what cam you have aftermarket or stock but make sure it has a lobe for the fuel pump push rod. if your going from efi to carb you need to check that first before buying a fuel pump.
Old May 21, 2006 | 02:26 PM
Car: Trans Am
well i used to do research thats why I only got like 200 posts. But since they switched everything around i can't research anything i just get an error WTF is with that??? so i have to ask
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
