Secondaries not opening all the way
Old May 24, 2006 | 04:38 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
hi,
are the secondaries supposed to be like this at WOT? (sorry for the cellphone pic. i get better pics when my camera is here, but you get the idea) its a 650 double pumper
i can bend the little rod a bit so that they are fully open, but then they are too much exposed at idle.
any ideas?
nebu.
Old May 25, 2006 | 03:10 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
*bump*
Old May 25, 2006 | 04:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bend the link as much as you can without affecting the "closed" opening. 650 cfm on a 305 is not going to suffer with slightly less than fully open secondaries.
Old May 26, 2006 | 03:45 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
ok
Old May 26, 2006 | 03:09 PM
SteelTownMadDog's Avatar
That's normal for secondaries on a Holley. I had a 700 awhile back that was the same, and also my modified QJet is the same.
Old May 26, 2006 | 03:30 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Hmmm....I don't know if it's "Normal" for Holley's. Never used anything smaller than a 750 though.
You can't compare Q-jets to Holleys. Q-Jets puposely don't open the throttle blades to 90deg because of the HUGE difference in size between the Primaries and Secondaries. The Q-Jet secondaries are designed to deflect the air\fuel stream towards the front cylinders to equalize the mixture. Modifying the linkage on a Q-jet to open 90 deg can cause the rear cylinders to run rich and the front cylinders lean.
Pac J
May 17, 2020 10:44 AM
racereese
Oct 10, 2015 09:39 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
