2 fuel pumps on carburated car?
Car: 92 F-bird, 1965 Goat (GTO for those who don't know what a Goat is.)
Engine: 3.1 V6, 400 w/3 2 bbl's
Transmission: 700-R4, TH350
I have a question. I bought an '87 Firebird with a carburated LG4 for a parts car. I have a 1992 Firebird V6 that I am going to swap to a carburated V8, hence the parts car. I am going to put the LG4 in the '92 temporarily until I can get my other motor finished. (Building a 383) I am getting rid of all emmissions and computer equipment and going with an older HEI and carb.
My question is the LG4 has a mechanical pump on the block like all traditional small blocks have. Well, I pulled the tank to get the fuel pickup because I thought it would be an older type without the electronic pump. But, to my suprise, It had a pickup with an electronic pump also!? So, is this stock from the factory? I have heard of people running an electronic pump with a carb using an adjustable regulator, but there was none on this car. The car ran great when I got it because I drove it before I took it apart. I just can't figure out an electronic AND a mechanical pump being on the car together. I would rather get rid of the electronic pump if possible.
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Dont quote me but I think some of the 305's had a mechanical and a "helper" pump in the tank. I think they came with the HO motors.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Some cars had the in-tank electric pump from the factory, some had it added by the dealer to prevent vapor lock.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i'd suggest in your future setup, remove the fuel pump from the '92 car, (in tank) and just get a normal fuel pump (block mounted) and run that only. A return style pump preferably.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
