Pissed off in ohio
Old Jun 5, 2006 | 09:13 PM
blockhead1986's Avatar
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
Pissed off in ohio
alright i am running a mechanical fuel pump but runs through the factory electric pump that doesnt work i can start the motor with starting fluid and it pumps fuel up to the carb with engine running it wont stay running what do i need to adjust help please
Old Jun 5, 2006 | 09:50 PM
Firebird1984's Avatar
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
My "guess" is that the mechanical pump just can't cut it trying to draw fuel through the dead old electric pump in the tank. The electric pump "rotor/gears" are not turning and you are expecting the mechanical pump to pull fuel through that restriction. It may pump fuel up there (it takes starting fluid to give it a "push" as you mentioned), but I believe that this is too much of a drag on the mechanical pump. Have you installed a fuel pressure gauge in the line to see if it maintains pressure after it starts?
It sounds like you may need to drop the tank and either put in a new electric pump and a regulator up front, or ditch the electric pump in the tank and put in some kind of "homebrew" pick-up tube so the mechanical pump can do it's job without interference. Keep us posted and good luck!
Brad
PestilenceIV
Sep 11, 2016 12:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
