hood clearance
Old May 24, 2006 | 12:10 PM
loud_mouth22's Avatar
Car: trans am 86
Engine: 383
Transmission: 700
hood clearance
anyone here use the air gap with an elderbrock carb will this clear the hood and with what air cleaner
Old May 26, 2006 | 03:12 PM
SteelTownMadDog's Avatar
Just the regular Perfomer Air Gap will, the RPM version will clear also if you're just using the regular air filter assembly that came with carburated FBodies. Or, you'll need at least a 1.5" drop base if you want to run a 3" element. That's what I have with the RPM intake.
Old May 26, 2006 | 05:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'll need the banjo fitting for the fuel line when using a drop base cleaner, and you may have to get a 1/2 inch plastic spacer (mr. gasket) as well, to clear the linkage and electric choke (if you have). With the spacer, you may have to reduce the element size to 2 1/2 inches for the hood to clear - I had to go this route with my performer RPM and 1406 carb.
Old Jun 4, 2006 | 01:21 AM
Car: trans am 86
Engine: 383
Transmission: 700
thanx for the help guys
Old Jun 4, 2006 | 10:35 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Ill let you know hopefully in a month. Im trying to fit a SBC with new motor mounts, RPM Air Gap and a 1411. Wose part its going under a firebird GTA hood.
Old Jun 4, 2006 | 11:31 PM
Car: trans am 86
Engine: 383
Transmission: 700
what do you use for a throtle cable bracket with this combo
Old Jun 4, 2006 | 11:59 PM
Car: trans am 86
Engine: 383
Transmission: 700
also my oil sending unit is to large of a diamater to fit this intake are there any others out there with this problem
Old Jun 5, 2006 | 10:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use an extender fitting. Hardware store.
Old Jun 6, 2006 | 09:25 AM
Car: trans am 86
Engine: 383
Transmission: 700
can i put a 90 on it also
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
