Question about Idle mixture screws
Old Jun 11, 2006 | 06:29 AM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
I was wondering how the Idle mixture screws work when you turn them in and out. What happens when you turn them out? Does it richen the mixture or lean it?
Old Jun 11, 2006 | 07:46 AM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
berlincam86,
CCW (Out) Richens, CW (In) Leans.....
If your car has a CCC (Computer Command Control) Rochester you really don't want to mess with those screws unless you are following the complete and proper adjustment procedure. Haynes published a very good book that is a great starting point for anyone that wants to adjust a Rochester. AutoZone has it for about $15. Adjusting those screws without following the proper procedure is asking for trouble
Haynes - Techbook - Rochester Carburetor Manual #10230
IMPO - Get the book, read it, read it, read it THOROUGHLY, and THEN go for it!
Sincerely,
Kurt
Old Jun 11, 2006 | 09:22 AM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Yep I have that book. Still have to read it but I was just curious on how they worked. Thanks for the info.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
