Q-jet Vs. Street Avenger
Old Jun 11, 2006 | 10:00 PM
IrocNrollCamaro's Avatar
Car: 1980 Z28
Engine: Turbo-Jet 461
Transmission: Super T10 (currently dead)
Axle/Gears: 3.73 posi
With the sky rocket in gas prices, i was worried about my wallet and tight budget, and Holley, not being the best fuel economic carb company, i had doubts. i stuck the little fuel economic spring in my avenger, but that didn't make much a diff. Im considering putting a quadrajet on my 454, but from what i've heard they aren't the most reliable carburetor. Also, what would has the better performance? my street avenger is 770cfm. i'm new to carbs, so anything to point me in the right direction would help.
Old Jun 11, 2006 | 10:27 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have a Holly 670 double feed carb and I HATE IT, I would rather have a CC Q-jet and you can take that to the bank!
Old Jun 11, 2006 | 11:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The spring of which you speak only affects secondary opening. So, if you are babying it enough to worry about fuel economy, you aren't going to touch the secondaries at all. If you like, you could even disconnect the secondary diaphragm rod to make sure they never open, but I doubt you'd notice any difference if, again, you are driving it with fuel economy in mind.
The q-jet is the fuel economy king of open-loop mechanical carbs. However, what's the break-even point after spending $500 for a carb? The reliability statement sounds like something from someone who is too stupid or too lazy to learn how a q-jet works.
Old Jun 11, 2006 | 11:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Gm thought the Rochestor quadrajet was reliable enough to put them on about a bazillion vehicles, and warrantee them. They're good.
I wouldn't spend $500 on one though. If you can get one from the JY, and tune it up right, you might save some cash on fuel. Ok, you probably will, plus you could sell your avenger and get some more moola.
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
86CamaroDan
Sep 29, 2015 10:08 PM
makaveli09
Sep 15, 2015 10:43 AM
