TPI to Carb
Old Jun 21, 2006 | 11:38 AM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
TPI to Carb
i have my car set up with TPI fuel line's and am going to be switching it over to carberated not i dont feel like putting the carbeated lines and sending unti back in so i was just gonna run with the electric pump and get a regulator now can any one recomend which regulator to get and what about the fiitings, do i have to get those Accel one to switch it over to 6AN???
Old Jun 21, 2006 | 12:53 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I'm not sure how good it will be to run the TPI pump regulated down to 6 psi for a carb. TPI puts out something like 40-45psi... I bet it will shorten the pump life considerably. Maybe someone else out there has done it with good results, but I wouldn't do it on my vehicle.
If you want to keep things simple, just drop the tank and convert to a mechanical pump. Second option would be to install a TBI pump instead of the TPI pump and regulate THAT--14psi down to 6psi is a much better idea in my book, and that's what I'm running in my car.
Make sure to use a return style regulator--I use the Holley 12-803BP (Summit PN HLY-12-803BP).
Old Jun 21, 2006 | 01:31 PM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
ahhh u are right cuz i set up my buddy car to run carb but his was a TBI and i thuink he was running a mallory 3 port or mabey 4 with a plug in one
i still have my carb sending unit---i knew i saved it for a reason
Old Jun 21, 2006 | 08:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A pump builds pressure by having the flow restricted. A TPI pump only puts out 40+ psi when the return flow is orificed down. A TPI pump in a TBI system will put out 9-10 psi, because that's what the TBI reg allows - the excess flow is returned to the tank. A TBI-specific pump will have less flow capability than a TPI pump because it doesn't need to build up as much pressure.
When regulated down with a return-style regulator, a TPI pump will work fine with a carb. The Mallory 4309 is such a reg - the number of ports is moot, because you can have a dead-heading reg with multiple outlet ports. What's important for using a factory in-tank electric pump is that it is regulated with a return-style regulator. The constant flow through the pump cools it and keeps it from burning out. It will last longer, theoretically, in a carb system than it will in a TPI system.
Installing a return-style reg is probably easier than dropping the tank. Sooner or later, the factory pump will wear out/fail, so you'll be dropping the tank sometime, anyway. When/why you do that is up to you, but in my mind, an in-tank electric pusher pump with a constant return is the ideal set-up with a carb for prevention of vapor lock.
Old Jun 22, 2006 | 06:50 PM
redbandit98's Avatar
its probably not "correct" but its worked for 3 years for me and a few others i know, i just left my in tank pump, put an inline holley red where the fuel filter goes, and pull through the stocker. Ive got a filter and a guage right at the carb and it reads 8psi all through the band.
Old Jun 23, 2006 | 08:40 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I've run my TPI pump threw my mallory regulator for 7 years now and have had no problems at all.
Old Jun 23, 2006 | 10:25 AM
99Hawk120's Avatar
I stand corrected. I suppose that shows how much I know about TPI, huh?
Old Jul 12, 2006 | 01:40 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I am running the mallory return style AFPR also with a TPI pump.
I wired the pump to a 12v source when the key is on. I would like to fix it so that it primes like factory instead of continous running. If I have the key on and not started, it fill the float bowls up.
Old Jul 12, 2006 | 06:06 PM
contact's Avatar
Engine: sbc 350
you might want to think about,
keeping the TPI regulator,
and hooking the supply side to a deadhead 6psi regulator.
that will, keep fuel constantly flowing out of the fuel pump,
because the TPI regulator is still in place,
but allow the use of a low cost carb regulator
Old Jul 18, 2006 | 11:36 PM
fenton06's Avatar
does anyone ahve a p/n for the regulators they are using w/ the return lines?
Old Jul 19, 2006 | 12:22 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Try mallor part#4309
Here at summitracing.com Mallory Fuel Pressure Regulators: MAA-4309 - summitracing.com
Old Jul 19, 2006 | 08:49 AM
five7kid's Avatar
Have you or anyone you know tried that? By "supply side", do you mean the output of the TPI reg?
I would imagine plumbing that would not be exactly straight-forward.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
