tricky q-jet
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
First, let's establish one thing: Make what run better?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
more specs.
is the q-jet computer controlled, or not? Have you ditched the computer?
Distributor, which one are you using?
which cam exactly?
how "bad" does it run? I mean, what kind of bad? Poor starting? Bog? etc etc?
which cam exactly?
Originally Posted by 69chevy_c10
stock 350 w/ double hump heads and a mild cam
Like:
What do you have for exhaust?
as far as the exhaust im running headman headers 1 5/8 in. primarys 3 in. collectors, H-pipe dynomax bullets then dump. the cam is 310/310 d. and .485/.485 L. and it boggs to beat all hell and i have tryed damn near everything but replacing the carb wich i should but i cant afford it right now cus im doing body work
Car: 1982 Trans-Am
That is NOT a mild cam. It's fairly wild actually. Still need more info, brand, part number, duration @.050.... Might be able to guess it based on that info, but the cam doesn't ring a bell of the top of my head... An old comp magnum grind perhaps?
It'll bog alright, you'll need to tweak the carb a fair bit to get that running right. First, is the torque converter stock? That'll help it bog a fair bit. I think the powerband of that cam is in the range of 3000-6000RPM or so.
is it the stock, computer controlled carb? choke, plus the 2 electrical connections? Is it the stock distributor??
A bog upon going WOT (assuming that's when it bogs - you weren't specific) is a combination of 2 things - the adjustment of the air valve tension, and the condition of the choke pull-off. If you removed the choke, and removed the choke pull-off in the process, you just made a bog machine out of your carb.
You can eliminate the choke pull-off, but that's a matter of extensive modifications to the secondaries to make the AV the sole controlling factor. Better in your case, if you've removed it, to put the choke pull-off back on.
Oh, and the computer doesn't control the choke. . .
sry im so bad at getting my facts across.
yeah it is at WOT and i did pull the choke pull-off, so i will put it back on and c how she does.
and with the computor thing i just ment i was tired of all the wires plus my choke was jacked up so i cashed the electric ckoke and put on the manual but is just a pain to tune
You need the link that goes from the pull-off to the AV. Make sure the pull-off holds vacuum (I just had to replace mine, it would bog from time-to-time, not always, found out the pull-off leaked - it would pull to full stroke when the engine started, but would release at too high of a vacuum).
