carb swap problems
Car: 1989 camaro
carb swap problems
alright well im nearing the eand of my swap and i have a holley 750 carb going on a 383 but my throttle cable is either too short and won;t reach the throttle bracket on the carb or bracket that holds the throttle cable is wrong and i need a different one. any one else ever had this problem or know of a solution
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I had the same problem when I installed my 750 holley. You need to find an adjustable bracket for the accelerator cable. Jegs or Summit should have one. I also had to adjust the cable where it hooks in the accelerator pedal. There should be 2 pressed on rivets on your cable with a plastic piece that fits in your accel pedal. Mine was set on the bottom setting so I had to change it to the top setting.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i picked up a throttle cable from a camaro same year as mine and it was plenty long enough, and i also ran an adjustable edelbrock bracket on the intake and it works great.
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
You can get what you need from AutoZone. They have the right bracket in chrome in their performance isle. Thats where I got mine from.
theshackle
Mar 5, 2017 06:37 PM
