This may be wrong
Old Aug 4, 2006 | 09:36 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
This may be wrong
when i bought headers for my car it didnt have any opening for an O2 sensor. So i took the passenger side to a weld shop and they welded a bung in for me. Is it a bad thing that it is on the passenger side? I read that it should be on the drivers side but no explaination why. any ideas? any comments?
i only ask because the car is running very very rich according to my A/f guage.
Old Aug 4, 2006 | 01:17 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Well, I personally don't see the difference, as long as it is the same distance from the motor. If it is a one-wire oxg. sensor, its accuracy is more of a lack of. I don't have the chart on hand, but the voltage table was very slopey compared to the air/fuel ratio. That = not very useful.
However, if it says you are running very rich under all conditions, I would say it is a safe bet that you are. It should go stoich or lean under cruise conditions. Again, it's not very reliable.
Also remember, to make the most power, the ratio should be rich. I think about 11:1 for max power. 14.7:1(stoich) is just the ratio to get the cleanest burn
Old Aug 4, 2006 | 02:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The factory put it in the driver's side because the EFE valve was on the passenger side. It wouldn't get any flow or warm up until after the EFE valve opened, which is too late for closed loop operation.
Where is your A/F gage sensor?
Old Aug 5, 2006 | 02:30 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
are you putting in the stock O2 sensor for computer use, or for your personal A/F readings?
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
